- 14 Oct 2007
- newcastle
Which is the Best RAM for a lower airflow/hotter case, I currently have 4x8GB G.SKILL TridentZ RGB Series C14 Samsung b-die, which apparently doesn’t do too well upwards of 55c, with the addition of my 3080 it’s dumping a lot of hot air into my case(hoping that changes when my waterblock comes), which is Inturn heating up my RAM(never had the problem with my 1080ti). I take it I will be better with 2x16gb sticks rather than 4x8gb sticks so I can get some airflow around the modules, which chips are more resistant to higher temps? nothing I can really do about the airflow in my case it’s a O11 WGX ROG with rads top and bottom.
edit, it’s definitely the airflow, take the glass side off and the ram drops down to 42c
