Hi, a few questions i need help with.
i'm looking to get some new memory for an upgrade with;
Intel Core 2 Duo E6850 "LGA775 Conroe" 3.00GHz (1333FSB) - Retail
either;
Gigabyte GA_P35_DS4 (Socket 775) PCI-Express DDR2 Motherboard
Gigabyte GA_P35_DS3R (Socket 775) PCI-Express DDR2 Motherboard
i can't decide.
i've currently got an a8n32-sli Deluxe, and a 939 amd 64x2 4200@2625mhz with 4x1gb of crucial
ballistix pc 4000. i'm running vista 64 ultimate.
having 4gb affects my read/write/latency times going from 1T to 2T
using everest read/write on 2 gb is 7813Mbs/7019Mbs/56.8ns
using everest read/write on 4 gb is 6986Mbs/4695Mbs/55.4ns
so latencys slightly better on 4 gb but read/write not good atall.
saying that vista ultimate definetely runs smoother with 4gb rather than 2gb imo.
anyway, so for my new build i still want 4gb of ram.
3 questions, cheers in advance
are read/write times affected going from 1T to 2T with ddr2?
if so, would i be better buying 2x2gb of ram to run in 1T or 4x1gb to run in 2T?
what would be the best combination of ram to go for, taking into consideration my new cpu/mobo?
i'm unfamiliar with core 2 duo and ddr2 so i'd really appreciate some advice
either;
i can't decide.
