best ram
What is the rest of your spec?
Usually more more ram is better.
will be used for video editing
intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor -
Gigabyte Radeon R9 270X WindForce 3X OC 2048MB GDDR5 PCI-Express
ram ????????????
Gigabyte Z87X-OC Intel Z87 (Socket 1150) DDR3 ATX Motherboard
Antec High Current Gamer 750W Modular '80 Plus Bronze' Power Supply
Antec P280 Super Midi Tower Case
Microsoft Windows 7 pro SP1 64-Bit -
Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic -
Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic -
Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (
Thermalright Silver Arrow SB E Extreme CPU Cooler TY-143 Fans
NZXT Sentry LXE Touch Screen External Fan Controller
Fan Antec TrueQuiet 120 Blue LED 120mm Fan x2
LiteOn IHAS124-14 24x DVD±RW SATA ReWriter (Black)
Performance varies just about nothing unless you're running Crossfire/SLI, but if you want the best, 2400MHz at C10 latency (it's not very cheap).
what do you think of this
http://www.overclockers.co.uk/showproduct.php?prodid=MY-174-GL&groupid=701&catid=8&subcat=2423
just to pick your brian on mobo gigabyte z87 oc or asus z87 pro
Doubt that will fit with your air cooler.
Can you see clearly the two orange slots if you look down at your board with the cooler in place?
Edit, wait, you aint got the board yet have you?
A small correct on RJC's suggestion, orange themed RAM - http://www.overclockers.co.uk/showproduct.php?prodid=MY-046-TG&groupid=701&catid=8&subcat=2429
