best range of budget bikes ?
14 Dec 2005
i see the supermarkets/halfords/argos and many more do really cheap bikes
looking to spend as little as possible really, only want the bike for keep fit purposes
can anyone recommend a specific brand/shop to go for ?
Decathlon are pretty much the cheapest when it comes to new bikes that are worth having. The Halfords Carrera range is okay, though I'd stay away from their cheaper ranges. What's your budget, and which sort of bike (i.e. mountain, road, touring etc.) do you want?
I volunteer at a bicycle re-use charity and we see a lot of supermarket bikes once they get to around 6 months, a year old and people ditch them
They are rubbish. Avoid.
hadn't really thought about what kind, mountain bike probably, even though it'll mainly be used on roads/pavements
if you don't want a road bike but will be sticking to roads/pavements and maybe the odd fairly smooth dirt trail then get a hybrid.
same wheel size as road bikes but tyres upto twice as wide and most have them have front suspension if you really want it.
but front suspension will just slow you down , on mine I can lock the front suspension so there's no travel and it makes pedalling so much easier.
if you just want something dirt cheap find out if there is anything like this place near you
http://www.recyke-y-bike.org/
they fix up and sell donated bikes , you can also pay to use their workshop and tools for uber cheap and they will guide you through any repairs if you don't know how
As said already decathlon or the carrera range at halfords. That said my wife has been pleased with an aluminum framed apollo from halfords.
I got an Apollo from Halfords 2 and a half years ago to go to and from work (3 miles a day) and it still functions well (despite never cleaning/servicing etc).
Cost me £80.
If I was doing longer distances Id want something better, mind.
would it be safe to say Raleigh aren't that good ?
can't find much good written about them anywhere, just thought with it being a 'famous brand' they'd be decent
No. They are making some good bikes now.
I think they rested on their laurels for a while. They're picking their game up again, and starting to make some decent bikes. I think most of the good ones would be north of a grand, though.
Raleigh via Halfords will the same catalogue shop crap. Raleigh do sell great bikes through local shops.
They have a race team and are plugging the hell out of it. Shame the company leave a lot to be desired.
For an extra £50 on Halfords website you could get the Carrera subway LTD and it will be a lot better than the Raleigh you linked.
It's basically a rigid MTB with slick tyres so can take a punishment, the gearing is a lot better, the frame is a good alloy mtb frame vs cheap steel and the parts you can't see are better too.
looking at spending at least £200 now, the subway had caught my eye yesterday actually
dug out my old specialized rockhopper today, and although the gears/crank etc are all worn (I remember taking it to get fixed ages ago and being told it was past economic repair) it still feels better than some cheap bikes I've tried
is the Carrera Subway Ltd the same sort of quality as my old rockhopper ?
edit - it's about a 1994 rockhopper btw!
I'm in the market for a bike to try and get fit, want a cheap one to start off with.
Any thoughts on the following 3 bikes for price and spec?
http://www.halfords.com/webapp/wcs/..._productId_922811_langId_-1_categoryId_165499
http://www.decathlon.co.uk/kemmel-id_8273887.html
http://www.decathlon.co.uk/rockrider-50-men-id_8202062.html
Halfords bike is Raleigh Scafell and seems to be half price at the moment, so if people have thoughts on that compared to the 2 Decathlon bikes that would be good.
