As per title. The old fairing set has got some heat proof foam on the inside. The Ebay special replacements do not have this, and I think it prudent to put some in. 5/6 OEM parts are available, but is pricey at over £120 for the five bits, plus I'd have to do something else for the last bit anyway.
So - what should I use instead? There's closed cell foil back foam in various places, would that kind of thing work? Some are touted as "GlassMAT XR Foil Faced Self Adhesive Van Liner Insulation" and other stuff as "Self Adhesive Reflective Aluminium Foam Insulation 5mm Thick"
Cheers
Cheers
