Best replacement Wifi Router
6 Nov 2002
Reading
I have a troublesome SKY Wifi Router with my SkyFibre.
I want to replace this, so whats the best (Up to £100) that I can buy for this purpose?
Sky won't support routers not provided by them. You won't even get a username and password out of them to use with third party equipment.
Great, so I need to battle to get them to replace the home hub thingy?
It keeps dropping wifi connections, or not letting devices join the network even with the correct password.
I use a TP Link router running DD-WRT with my SkyFibre. Most new Routers can work with SkyFibre they just need a bit of tinkering. I think the ASUS RT-AC66U is the pick of the bunch just now. Check out the SkyUser forum for more info and guides on how to set it all up.
