Best RGB 120mm Fans For Radiators?
18 Dec 2008
Liverpool
So it's new PC build time and I want/need new fans.
I have no set budget, I just want the best.
Having got the first gen uni fans, and being disappointed by the absolutely awful quality of both the wiring (incredibly flimsy and easily broken) and the fans themselves (rgb burn in and failed bearings on multiple fans) I'm rather dubious about getting the new inf uni fans.
So, what's the best RGB fan? For both radiators and with consistent bright RGB on both sides?
If you have the inf uni fans, what's your experience?
If budget isn't an issue, get some Phanteks T30 and the Phanteks Halo frame.
Going for a RGB fan, no RGB fan will ever perform as high end no-frills fans.
The Corsair ML I tried and was good at low rpm but noisy over 600 rpm. The QL can be a good choice, but them you'll need to go all in with Corsair controllers, etc.
Rgb fans if you want something to unicorn puke your setup nobody does it like the Corsair QL fans. Granted the Ml series is better for a water cooling setup. But if it bling your after than the QL series is easily at the top of the list.
But I warn you the cabling hell that is Corsair fans and the resultant controller boxes is a nightmare. I should know I have been running Corsair fans for a very very long time although the moment noctua does RGB fans I am switching
