Best Router for Live
14 Sep 2009
Northumberland
As its more of a general Q, I thought i'd ask here. I need a good value router, which doesn't lose the line much, which is also good for live, and can't be like my home hub, which has an NAT that is STRICT!!
I though of THIS. reviews say its good, but elsewhere they say its not. Can anyone help? :D
I'm finding newer Belkins to be pretty decent. the old ones were pretty poor, but some of the newer ones are proving to be better than the equivalent netgear.
About £40 max really, and yes:
PnP doesn't work by itself. That off and ports forwarded, doesn't work! Suppose WoW will do for now, no CoD though :(
I like BT's answer on their site though :)
Setting the games device's IP to always be the same should fix the NAT setting."
And you know what, that doesn't work :p
