- 9 Jun 2009
Hi guys, so basically I have a friend with a massive house and the router is at one end, and he needs the signal to get to the other end. There is about 4 walls and an outside wall (from extension). He has a wifi extender but it can't be put far enough from the router to get to the otherside. Can't use homeplugs as there are 3 separate circuits in the house and I know some go through boards but I don't want to bother tbh. So I think the answer is getting a better router that will hopefully get further through the house. At the moment its a cheap wireless N. He has virgin so it needs to be a cable router.
So in conclusion I need the best cable router for range for less than £120.
Thanks in advanced
Thanks in advanced
