Best Router for VM?
What's wrong with the supplied one? Admittedly I'm only on 70Mb, but unless you need advanced features like VPNs, QoS, load-balancing, etc. I've never had any problems with my SH2.
I use a TP-Link Archer C7 on my Virgin 150mb connection. Got it for £60 and has been rock solid and stable.
This website is useful - http://www.smallnetbuilder.com/tools/charts/router/view as it allows you to see the WAN to LAN throughput. My previous "gigabit" router would only give me 110mbs on Virgin as although the LAN was gigabit (ie between two PCs connected to LAN ports on it the speed was 1GB, but anything coming from the WAN to these devices couldn't get the full 150mb from Virgin).
If you've got a new Superhub 3 (white one) then it might be worth giving that a go first to see if it meets your requirements. Unless you're after more advanced features anyway that is.
