Hi,
When I've done my first lapping I thought sanding paper was.. sanding paper and nothing more.
But I run out some sheets and accidentaly bought "unknown" paper. I was very impressed that lower gritt sheet is as much good as higher previously-used "old" sheet in finishing terms.
So far I discovered:
* Klingspor - is good in low gritt values (400) which scuffs nikel layer well, and sometimes is able to almost polish copper layer. 600, 800 and 1000 gritt values are not so good, and 2500 gritt sheets barely make CPU a shine. Klingspor is being sold in A4 size.
* Tamiya - best for finishing IMO. Final effect with polishing using 1500 gritt sheet was better than using Klingspor 2500 gritt, and costed me less time. Tamiya are being sold in some exotic size, like 3.5"x10", and are more expensive.
What was your experience with sanding paper brands ?
Sometimes I think people read just the title and give the "default" answer. I'm curious what Turing's test whould say in such case
