Best screen protector?
25 Sep 2003
Merseyside
K800i screen has seen better days, just trying to track down a new screen for it, when i get one i want to protect it, seen clear films to go over it, whats the best one?
Martin Fields are the best without a doubt.
They arent cheap, about £10 for a small piece of plastic film!!.
but.
ive used other protectors on pda's etc and nothing comes up to the standard of a Martin fields one.
Ive just installed one on my Vario II and you cant tell its even on the screen, it lets 90% of the light through so you dont loose any brightness/contrast, compared to cheaper ones that dull the screen and make it look washed out.
I got a Brando one for my Mini S - again, no dulling of the screen and it actually reduces glare. Very easy to apply and you can't tell its there.
They are expensive for what they are, but just a bit less than the cost of a new screen.....
