Best Silm 360 Rad
RSR
RSR
17 Aug 2006
Evening All,
As i'll be upgrading my loop soon, I am looking to swap out my current EK SE 240 for a slim 360 Rad.
I'm considering the following:
EK-CoolStream SE 360 (Slim Triple)
Black Ice Nemesis Radiator GTS 360
or I'll need to do a bit more modding to allow for a EK-CoolStream PE 360
At the moment, the GTS seems to be more favourable rad but I am open to options. What are the views and opinions on both or these or can anyone recommend one other.
This will be going at the top of my Phanteks Evolv ATX.
Thanks.
Thanks.
Is it because you already have 360 in the front?
Yup, I have the dremel at the ready. Just looking at the rad options at the moment. I've test fitted the fans at the above my current rad which seems to work well.
Thanks guys, also from looking at the results it seems the GTS performs better than my EK PE 360 rad as well. So it looks like I am swapping both out.
Thanks all.
