Presently, no unfortunately. Will take a lookdo you have a pressure washer with a snow foam lance? I've started using Autoglym Polar Seal, it's absolutely excellent and so easy to apply.
meguiars quik detailer is very good and quick.
For a more traditional paste type wax, Bilt Hamber Double Speed Wax is hard to beat for ease of use but you'll really want a finishing polish/glaze first to enhance the shine.
If you want something that'll do a bit of a polish and wax all at once, AutoFinesse Tripple might be more up your street.
But is not a wax.
This one?Maguires Caranauba wax is a cracker... smells lovely and very very easy to wipe off. Gives a great shine
Yeha you can use that but I find it takes too long, I used it and it is good and if you have the time... I mean this one which is the liquid form of that one... just faster to apply and polish off really, but yes both of these are quality. I really rate them!This one?
Meguiar's G7014EU Gold Class Carnauba Plus Premium Paste Car Wax 311g https://smile.amazon.co.uk/dp/B001MPST3M/ref=cm_sw_r_apan_glt_fabc_Q5X6GDS83Q3M7QY0GS06
Collinite 476s is a real enthusiasts wax, no added gimmicks just a hard working and durable wax. This wax stands up to rain, snow, salt, dust and grime so is perfect for a winter wax when you need that extra protection. Collinite 476s also protects against UV so good for the summer months too. In fact Collinite claim you can get up to 12 months protection from 476s.
With all that durability you might wonder if you miss out on shine, well actually no. Collinite 476s adds a real deep gloss to solid colours and makes metallic flakes come to life.
Collinite 476s is a carnauba based paste wax with no cleaners. When you come to applying Collinite 476s use a foam wax applicator pad, allow to cure before buffing off with a microfibre towel, for best results apply in multiple thin layers.
But is not a wax.
