Best single fan closed loop rad unit on the market ??
20 Jan 2009
Question Best single fan closed loop rad unit on the market ?? (small for itx system)
Its too thick because of the 49mm radiator and 2 x 25mm thick fans if you know what I mean, its the corsair H80i GT.
Please help me, I need a answer as soon as possible hopefully on this please as I was wanting to get it complete tonight.
I am stuck with a dilema here, in my new build with the small case the node 304 I cant squeeze in the corsair 80i GT with dual fans but it will fit with just one fan but I cant find any info on them to say how good it would work with just one fan, does anyone know ?
If its no good I can run down the shop and choose from a sealed rad system that only uses one fan but I have no clue what to choose and the shop will be closed in a couple of hours :(
Can anyone help me please please please ??
Going to try the H80 with just one fan as I cant find another solution, totally size restricted because of the case size, so I just need to hope that its a good silicone lottery for me, hmmmmmm......we shall see
