Best Sli Second Card ?????
30 Oct 2002
Here
I have a gainward 6800 GS 512Mb main card.
What would be the best 2nd SLi card to run with it ???
Thanks in advance
Try not to sli if u can get a better option in a single card solution (all depends on the value against performance here). Then in another 6 months, should your wallet start to overflow, u can sli with another modern card. I assume nvidia is the way for you.
my philosophy has always been not to sli, as when you come to upgrade next time it is more money wasted. and also in a weeks time there will be a newer card out which toasts your sli setup for around the same price. just stick with one card until you can afford the best card when you next do a full upgrade. that card should still be offering good performance as it is.
the only time i'd go dual is if i found a single card with 2 gpus that suited me.
daven
