Best Socket 939 Mobo atm?
uZi
uZi
1 Aug 2003
Need a mobo for an opty 170, 2gig of Gskill ZX and a x1900 xt and will be overclocking (duh) - Thinking of going for the DFI expert, although I won't be using the SLI.. obviously, also i'm doubting ill go for crossfire either. So basically, best clocking 939 board?
Cheers
I'm in the same boat as you, and I've read through reviews of the:
MSI K8N Neo4 Platinum nForce4 Ultra (Socket 939) PCI-Express Motherboard
"Although where this board really shines at is overclocking. On air, we were running the board without any hiccups at 370MHz FSB which is certainly saying something and part of the reason for achieving such high speeds is definitely the quality of components and engineering that went into producing this board. We’re very impressed with the K8N Neo4 Platinum Edition"
Need I say more? :cool:
I would also go with the DFI Lanparty series, they are extremely good boards and offer so much overclocking potential.
I didnt want SLI also and my budget was small so I got one of these
Under £50! From ocuk B-Grade - if it doesnt work i'll just return it.
