Energize said:Vbr should always be used tbh, far better quality.
I just virtual dub for dvd->x.264
Baron_Samedi said:Hi MadMatty,
Quick question is your dvbt source 350Mb?
Just trying to get a handle on the amount of compression...
Cheers
Oh and why do *you* use vbr?
Colbaker said:O.k. im running autoGK on a movie that is 1hour 51mins long on my X2 4400+, How long should it take?
Also it doesnt seem to give you the option to change the setting in divx or xvid, Does it set them itself?
