Best software/programming solution?
19 Jul 2006
Gibraltar
Hi guys,
I'm trying to load a sequence of images, one video and then a php page in sequence.
Can anyone recommend the best way to go about this? Was thinking of coding a page with php/javascript myself but not sure if this will load fullscreen like I need?
OP
19 Jul 2006
Gibraltar
Hi jsmoke, basically I need everything to be fullscreen. So first the images would show in a sequence, then one video, and then finally a php page as it will be showing fixtures from an xml feed. I just don't want any address bars showing, I want everything showing in fullscreen so it seems like a seamless image sequence. The final 'image' in the sequence would be a php page that loads a background images with an xml feed overlaying it.
