Hey,
I have a Draytek Vigor 2130n with 2.4GHz only, but the wireless throughput is flakey and can vary, which I think is due to the 30+ other 2.4GHz networks nearby!
I'd like to add a 5GHz access point, and thought that I may as well get an 802.11ac access point.
Are there any particular models which you guys would recommend? Or perhaps any routers + DD-WRT or similar?
Cheers,
Su
Cheers,
Su
