A flatmate of mine I'm building a pc for (primary uses being sound and video production) is after a suitable sound card, ideally an internal card, with a front panel.
Low latency is a must, the front panel isn't as vital, so long as multiple connections of various sound gear doesn't involve climbing round the back of his pc every single time.
From a brief look around M-Audio seem to be pretty decent, is there any particular cards you would recommend. Budget of no more than £100 unless there are some significant benefits for spending over this.
Cheers
Cheers
