Best Sound Card for under £70?
26 Jan 2007
Leicester/The Toon
Hey,
Just bought some 7.1 surround sound speakers, Creative T7900. I have a Abit QuadGT which has onboard 7.1, however I want to get the best out of my new speakers. Any recommendations?
Thanks,
Matt.
Xonar DX if you have a spare PCI-E x1 slot
X-Fi XtremeMusic if you don't.
Other than that - Avoid X-Fi XtremeAudio. If you're on XP, I could recommend other cards. If you're not a gamer or don't use Vista I can recommend other cards.
If you have an Abit QuadGT, I reckon you will have a PCI-E slot, so would go for the Asus Xonar DX....as already suggested.....
I have an X-Fi and I say the Xonar range.
If you don't have a spare PCIe slot for the DX, stretch the extra and get the D2. The X-Fi range aren't worth the risk that they might not work.
