OK I'm getting a new comp and have spent the last few weeks catching up with the major changes in the processor world and I'm having trouble deciding whether to go down the AMD or Intel route to base my new hardware round.
I've been reading a lot that with the release of the Core2 Duo from Intel, this has kind of blasted AMD out of the water but pricing is obviously higher.
I primarily use the comp for web design and development, more code than graphics though. Typically I will have Outlook open along with 5-6 IE windows, Dreamweaver and several RDC sessions.
In the background I have constantly running ColdFusion MX, IIS, MySQL etc
The most important aspect of a comp to me is speed and the ability to handle several resource hungry applications at once. I run two TFT monitors so I don't need a fancy graphics card (just twin DVI outputs) and I use the on-board sound as I don't play music etc through the PC. I do need a minimum of 2GB RAM though...
Finally I'm not adverse to building the comp myself, I just want to make sure that the parts I get will actually work together!
Advice and opinions welcome and apologies if this sounds like a noob question, my web development skills are better than my hardware knowledge
