Hey 8 Pack,
I was wondering what you find to be the best stability programs when overclocking a GPU. I overclocked my 7950 Windforce X3 to 1.2Ghz/1.5Ghz/1.3V using Afterburner which survived a 15 minute burn in test using Furmark but when trying the Valley benchmark at those speeds it crashed almost straight away making me think Furmark is pretty useless for stability?
This means that I've only really been using Valley benchmark to test the OC which I've found seems perfectly stable at 1.15Ghz/1.5Ghz/1.3V (I plan to see if I can lower this when I find a stable OC).
Any suggestions both in terms of stability testing and just general OC advice
Thanks!
?Thanks!
