best sub £200 cpu for gaming
7600 if new buid as the am5 will offer longevity otherwise the 12600kf can be had for around £160 , £20 more for 13400f
Are you gaming?
have an air cooler currently using the lga2011 cpu would like to use that again if possible, looking at the mounting bracket it has holes for a smaller fit.
assuming you bought your cooler at the same time as your x79/99 rig, your cooler will not fit unless the manufacturer has made an am5/lga 1700 mounting kit.
need cpu mobo ram have an air cooler currently using the lga2011 cpu would like to use that again if possible, looking at the mounting bracket it has holes for a smaller fit.
budget around £400
AM5 gonna cost you around the £440 mark with 32gb of DDR5.
7600 comes with a stock cooler so you can get one later if yours don't fit..
My basket at OcUK:
Total: £442.92 (includes delivery: £3.99)​
i will ditch the cooler and go AIO
With your very tight budget I'm not sure that makes sense, because it would have a big impact on what you can buy. A phantom spirit or peerless assassin is £35 and it outperforms many AIOs.
I'd consider a 12600KF (they're on sale just over £150) and a B760 motherboard like MSI's B760-P, or if you want DDR5, B760 Gaming Plus or B760 DS3H DDR5.
