In that case, the Pixel 7 can be had for £499 and is 6.3" or you can look for a Pixel 6 Pro in 2nd hand market for a bit less but is 6.7"Thank you. I have got used to the 6.67in screen. The step down in size might be a step too far. It might be a compromise I have to make though
Xperia 5's can be head cheap,
I've recently changed my Xperia 5 for a Samsung S21 Ultra and the difference in photo quality is night and day, I've now got the camera I've always wanted. The macro is to die for which I use a lot, the Xperia 5 can't do it.
My mate has just had the new Pixel so we did comparison shots in a pub and the Pixel just edged it.
I was considering the S22 for £350~ but I've never liked the look of Samsung's processing. Too contrasty and often overexposed from what I've seen.
Have they given up on bixby yet? / samsung bloat on my s21 5g sucked.I was considering the S22 for £350~ but I've never liked the look of Samsung's processing. Too contrasty and often overexposed from what I've seen.
Yes. It has a weak phone signal so only get the 6 range is you live in a good signal area.Is a Pixel 6 Pro worth an extra £35 over a Pixel 7?
Base s22 has an okay cam. Nothing special.I was considering the S22 for £350~ but I've never liked the look of Samsung's processing. Too contrasty and often overexposed from what I've seen.
Yep. Check you are happy with size as its bit bigger I think. GsmarenaIs a Pixel 6 Pro worth an extra £35 over a Pixel 7?
