Best sub £50 card?
8 Feb 2006
Hey people,
What, in your opinion, is the best graphics card on the market, sub £50?
I'm making a budget build, and was wondering if anyone had experience with budget cards? :)
budget as in, you want to play some games on it?
if you want to play games choose the normal 6600 128mb which is slightly faster and less likely to die than a 9800pro. but remember any card you can buy for less than £100 isnt going to be brilliant at playing games, it'll need lowest detail and a low res and will really struggle as newer games come out.
if you dont want to play games, then anything will do, ati 9250 or whatever their budget one is.
If after a new card.. then maybe ...
HIS Excalibur ATI Radeon X550 256MB DDR TV-Out/Dual DVI (PCI-Express) - Retail (RX550-256) (GX-041-HT)
Price: £39.95 (£46.94 Including VAT at 17.5%)
