Best thermal paste?
OCZ Freeze, non conductive, good price, does not need a cure period, is in the top of all the thermal paste tests I can find and works good for me.
Liquid metal wins it I believe, but is electrically conductive, quite fluid, and difficult to obtain
I'm using as5/mx2 on various things
Used AS5 for ages & can't complain, when I got my new hsf I decided to try MX-2, again can't complain.
Anything listed here is pretty much a safe bet, it's more down to how you apply the stuff most of the time.
**edit I just got that same heatsink & it is very good, I'm using MX-2 on it right now.**
I use the MX-2, but before i used the Zalman STG-1 (still got a tad left).. actually very similar temps (maybe 1/2c higher than MX-2) but also much easier to apply.
Changing subject slightly.....
I just had a look at this > Coolit Systems Domino A.L.C Silent Watercooling System<
Where does the digital read out panel go within the computer?
Looks an odd shape to fit in a drive bay.
dog-man
OCZ freeze is my favourite, no messing around just blob and fit. Performance is better than MX-2 in my experience (1 to 2C) and its unfussy nature reduces the chance of bad mounts.
For best performance I'd chose, and use, Coollaboratory Liquid Pro. It's a bit fussy, surfaces must be clean, and it can be a pain to remove. Get it right, a blob 1/2 the size of a small grain of rice is enough for an ihs and the base of a cooler, and it will easily make the most of your lapped set up beating OCZ freeze by the customary 1 to 2C.
it sits at the back left of the pc, the readout should be seen if you have a windowed case m8.
like so
Not my PC btw lol.
Don't really fancy it myself m8, it gets some ok reviews from what I remember though. I think some of the better air coolers (TRUE, Noctua & Tuniq) can match stuff like this & are probably about half the price too.
