- 15 Mar 2007
Anyone better than the others ?
Thermal grizzlyAnyone better than the others ?
yer but it isnt cheapThermal grizzly
Yeah that's true, a lot of other brands do it cheaper for the cost of 1 or 2cyer but it isnt cheap
Thermal grizzly
AS5 is the best. Always will be.
While AS5 is still one of my favourites there are definitely benefits to using MX-6 for the higher end Intel 13th and 14th gen and some AMD CPUs where the temperatures under load can be a crucial couple of degrees different - especially if using an air cooler can make a critical difference between thermal throttling or not and/or how long boost holds up for. A lot of reviewers (even ones who should know better) and end users persist in applying/testing AS5 incorrectly which has dragged it down compared to what it is capable of - although that in itself can be a problem in that it does require the end user to utilise it correctly to get best results whereas something like MX-4 is far more tolerant.
I always have to facepalm when a reviewer does a round-up of thermal pastes and states "I'm going to use the same technique with them all for consistency"... just no - read the application notes and use each paste as it performs best FFS.
