Best thing to clean hardware?
personally I like using a hairdryer...I have also found ex gf's make up brushes work well :D or just normal paintbrushes...cotton buds are pretty handy too...
this is my 5yr old PC after I got it back from a friend who used it for 2yrs...it took me a good 2hrs to clean it...
http://www.facebook.com/album.php?aid=87203&id=556137488&l=6651535d36
And all I used to clean that was cotton buds, wet wipes (Dettol ones :D), dust cloths and paintbrush. :D
yea i use compressed air, i do have 150psi Air compressor in the garage that i use :P
best way to clear any dust
The ideal solution of course, though requires an initial investment. I've been looking for a cheap one that'd be safe to use on PCs actually, fed up of expensive cans.
yea, mines mainly used for the Cars tyres bikes etc but it was about £70 from netto i think cheap n cheerful power craft!
Compressed air and various paint brushes, i usually blast all the dust onto the bottom of the case then hoover it up, though i recently took out my TRUE black and rinsed it below the tap, took ages for it to dry out.
I take the PC to a kindly local garage, and use their airline to blow out the dust. As I work around the case, I will jam the fans with a biro or something similar, to stop them turning and generating any back EMF. I've done this many times without any problems.
I have some pcp air rifles, so now n again i use hpa lol
Mainly as above i use a decent hairdryer on cold high flow obviously
Natural bristled paint brushes too, for 120mm fans etc i remove and use a stiff bristled brush (outside as you'd be amazed at all the carp stuck to the fan blades lol)
When cleaning my rads i blow opposite to the flow from fans, then just remove fans and clean as above
