Best time to check oil
9 Jun 2004
UK
I was wondering, is it best to check the oil level via the dipstick when the car is completely cold or after it has been running for a short while to gain the most accurate reading?
I've always been told to check it a few minutes after the engine has stopped running.
I always check mine in the morning when it's cold so I can measure the static oil volume rather than the oil less the oil covering the engine's internals.
HT
I always thought it was when the engine was cold, as if its warm then the oil level will seem lower than it actually is????
A few minutes after the engine has been switched off. This allows the levels to settle.
Anytime after about 30mins of driving or in the morning after leaving overnight. All the oil should be in the sump by then
I was told by both the official ducati dealer and the porsche centre that you check when the enging is at operating temperature (obviously turn it off furst)
that cos they run dry sumps...they need to be checked running....aprilia is the same
bullit
I have to do mine when it's cold as the viscosity is so low it just drips off the dipstick otherwise
