- 4 Dec 2007
Does rivatuner only show one core, if you overclock does it overclock both cores. If not can you guys recommend the app you are using.
cheers
cheers
cheers
Had pretty much no problem with mine - the odd driver revision hasn't liked it much - but thats it.
It isn't a card for the casual user tho - to get the best out of it you need to be something of an enthusiast.
I'd be prepared to call myself an enthusiast... It ws watercooled with a full cover EK block in its own loop with an E6700ES and I tried probably half a dozen drivers and various clocking tools.
I've never had anything quite so tepramental in all my building life.
suprised with that kinda hardware/software experience you couldn't get it to work... mines been super stable and reliable since I learnt how to use nHancer to modify/create SLI profiles for games that don't come with one.
hateful card... I was so fed up with mine by the time I got rid... install, run benchmark, fine... then oc and benchmark and the score goes down and wouldn't go back up until I reinstalled fresh.. etc.. just a very problematic card IMO.
