Best tubing with Mayhems pastel fluid?
Pretty sure the XSPC stuff is the one to avoid. Primochill or mayhems own brand is probably best.
Heard the plasticiser in the XSPC tubing starts to leak out into the loop and cloud the tubing.
Hmm, I found an old thread that said to avoid Primochill. It's what I have in there at the minute and there's discolouration of the tubing. I didn't realise Mayhems did their own.
I think if you look well enough you'll find a post about every tubing supplier having issues with plasticiser leaking into the loop.. I settled for Primochill in the end because of all the build logs I've seen that seems to be the most common.
The mayhems tubing is great - have been testing it for about a month now - too early to tell on leeching exactly, but otherwise nice clear tubing.
Mark
