Best TV around 43 to 46"
15 Nov 2010
Hey guys,
I'm after the best TV between 43" to 46".
Needs to be 4k.
Are there any UHD Premium TVs yet in this size?
If not can anyone recommend the best you can currently get?
Thanks a million
There was a Samsung 43 inch that was and still is best. But it's obsolete. I've been trying to find an upgrade to my 18 month 40" 4k sammy but I can't find anything worth the upgrade.
No premium ones in this size. I bought the LG 43UJ701V, which is excellent bang for your buck. Only thing it doesn't have is Dolby Vision.
Looking for a replacement panel for the bedroom as my old 7 Series Samsung LCD (still going strong) is now on the front line (in the uninsulated garage) for cardio :p
Having been very impressed with my LG 55EC930V I've got my eye on the 670V, needs are very basic. A quick skim and I can't see any significant difference between the 701? Or am I being blind? :)
If you're not watching from a wide angle, Sony kd43xe8005. Picked one up recently from JL and picture is absolutely superb.
I've been close to pulling the trigger on the KD43XE8004... Do you know what the difference would be between that and yours? The price difference is over £100 extra for the 8005.
Wish I could remember! 99% sure the 8005 has a 100hz panel and the 8004 doesn't. I'd need to Google. Difference isn't that big if you shop about.... ;)
I found the spec comparison. It looks like the only difference between the 8004 & 8005 is that 8004 has 100Hz MotionFlow and the 8005 has 200Hz MotionFlow.
Should that be a deal breaker? Will use for 4K Gaming and general Netflix etc..
