Best upgrade direction?
26 Nov 2003
East Sussex
Greets all :) Not kept up to speed with recent chips/boards and the like and now I could use a little advice.
I have an AMD Barton 2500 in a NF7 board, with 1GB (2x512) of Corsair XMS 3200, which I guess is a bit old now :S
It isn't overclocked any more, since my favourite game would regularly crash, no matter how long Prime95 ran, or how far I upped the RAM voltage etc etc. :(
The graphics card is a nVidia 6800 GT (I forget the brand!) with 256MB.
Now I think my graphics card is fine, it should be quite happy running World of Warcraft and BF2, imo, at high settings.
However this is not the case, I have to tone down all the settings - and this makes me sad :/
So what could be the reasons, from a Hardware PoV. I do tend to have a lot on in the background of my PC, could simply adding another 512 stick improve the performance? How would you alleviate this issue (in as simple a step as possible, I don't want a whole new machine :) ).
Thanks for any input :)
BF2 needs 2gb of RAM really, the 6800GT should run it fine.
You should consider an AMD 939 setup if you're on a budget, get a £40 mobo, a 3700+ for £65ish and 2GB of value ram for about £125
Total=£240ish
But, is the 6800GT AGP? If so, you might want to hang on a while untill it's fully obsolete
Helium_Junkie said:
939 boards have no AGP slots? :/
Some do.
The Asrock Dual thingamy has both PCI-E and AGP and is damn cheap. It's also exandable to AM2 and DDR2.
Get this board, a cheap cpu (3700 is bargain) and a gb of ram (doesn't matter whether it's 1gb stick or 2x512's, it wont run in dual channel either way).
Oh you also might need a new PSU.
I'd say that is your problem too, the CPU and RAM, an extra 1GB will be great for BF2 and a 64 3700+ to boost/smooth out performance generally.
3700 San Diego £64
Asrock 939Dual-SATA2 (Socket 939 & Upgradable to AM2) AGP & PCI-Express Motherboard (MB-002-AK) £42
And my current TwinX 2x512 Corsair 3200llpt, another 512 of same stuff pinched from second pc = 1.5GB. Perhaps by another 512 also...
Problem there is the need for a new sound card as well. Mine's PCI.
Is that the general idea?
