So recently I've been feeling that I'm missing out and due to software updates and game updates etc that my performance isn't what it once was.
I've done all the normal stuff like clean ups from day one I'm pretty confident that an aspect of my hardware could be changed round to generate the effect I desire.
My system is in my sig, and the options I have so far are:
Change 3570k to an i7 of sandy/ivy , hyper-threading, slightly more performance, possibility of unleashing more power (less CPU over-head for more GPU usage). £230+ new, hard to find on Members market and usually gets snatched up pretty fast. Possibility of selling my 3570k at around the £100 mark for regain of money spent
Add more ram, with more memory being used now days I'm finding myself in the most demanding games at around 2GB left of overall memory. I don't know if this would help at all?
Change from SLI GPU's to a single card solution, I love my 670's they add some flash to my rig but I'll be honest it hasn't always been smooth sailing. There are some games that just don't like or are not optimised for multi-gpu and they tend to be a complete nightmare, I end up disabling a GPU and lose overall performance because of it. In games that SLI works great (BF4, Crysis 3 and a handful of others) it's all smooth sailing bar my GPU usage isn't at its max because my 3570k appears to bottleneck the GPU's. I guess on this point I'd love to know what it's like with everything maxed without bottlenecks.
But my original point about games that I frequent not utilising mutil gpu's effectively the extra power usage and heat generated is not worth it so maybe a single card would be better? £300 new, multiple on the MM, possible recoup of £100 ish per card
Add some more SSD's, I have one SSD that the OS and a handful of games are installed on but the others run off an ageing 1TB mechanical HD that is noticeably slower on loading. £80 ish
Let's say my max budget is around £250-300 what would be my best investment?
Thanks for taking the time to read this
