Best upgrade from a 670GTX?
10 Feb 2011
Whats the best upgrade from a 2GBMSI 670 GTX at the moment?. I am willing to go up to £350 max but would prefer to pay £300. My current rig is.
Intel i7-3770K
Gigabyte Z77X-UD3H
Corsair Vengeance Low Profile 8GB Kit
MSI NVIDIA GeForce GTX 670
Sandisk Extreme 120GB Seagate Barracuda 2TB 7200Rpm
Antec P183
LG GH24NS90
Noctua NH-D14 Cooler
Antec High Current Pro HCP-850
Windows 7 Home Premium 64-bit
Thanks for any advice. :d
would that fit in that case with that big tower of a CPU cooler?. Also which version as there are a couple. I would want a 4GB and a Overclock easy as my gtx 670 is useless at overclocking.
I bought this PC in February 2011 and not updated anything in it. Should I upgrade the graphic card or wait for a windows 10 PC system to come out?. Will it be still worth the graphic card up now?.
If you did go with the Gigabyte for example, you'd probably have to remove that middle cage whatever it's housing as the Gigabytes a long card, or alternatively go with one of the smaller 970's.
I've just upgraded from an MSI GTX 670 power edition to an MSI GTX 970 and the 970 is almost the exact same size. The only difference is that the 970 needs an 8-pin and a 6-pin power connector, although it does come with a cable that converts a 6-pin to an 8-pin so you're all sorted.
Really happy with the new card which is super quiet and the performance improvement is notable. I've gone from around 40-60fps in BF4 at ultra & 1080p to over 100fps most of the time. Running a 144Hz monitor so can notice the difference, it's now buttery smooth all the time and looks amazing.
Can also add that my 970 overclocks superbly and sits at 1527MHz on boost for several hours at a time when gaming.
Settings with MSI afterburner 4.0.0;
Volts + 87mV
Core + 185MHz
Mem + 500MHz
TDP = 110%
FAN = set to 70%, almost inaudible at this speed
Temps during BF4 = 58-62max
