Best upgrade from Saphire 5770 ?
10 Mar 2011
Buying an upgrade tonight, what would you recommend as a best bang for buck upgrade from a Sapphire vapour-X 5770? Not sure if I should change to Nvidia, some good reviews on the 580 range . . . any advice?
Best price/Performance ratio is still probably 6850/460 1GB but they won't be a significant jump above what you already have. Not a wasted upgrade, but a 'better' upgrade is available for more money, such as the cards below.
Staying greenside I'd say a 2GB 560Ti. Redside the 6950 is the card of choice.
Agree.
A 2GB 560Ti or a 6950 2Gb will be at least twice the power of your 5770.
Cheapest upgrade would be another 5770. But Its upto you if you can put up with crossfire.
I would sell the 5770 and get a single card.
