hiho,
current spec
Intel C2D x6800 (65nm skt 775) @ 3.5ghz
Asus P5B DH Deluxe (975x chipset)
2GB Crucial Ballisticx
Ati 3870x2
used mainly for gaming @ 1920x1200. i play fps with lowest settings to get best framerates possible, so as much as i'd like a 4870x2, i'm not sure i'd be making best use of it heh (and i cant afford one either).
problems:
my mindset, 975x chipset seems so old :/
hard drives, currently i can only use 4 of the sata ports, the 2 other ports seem to automatically start acting as a RAID no matter what i configure. i have a sata pci board for another hard drive, but was looking to add another drive sooner rather than later. (so looking to attach at least 6 hard drives (no raid).
P5B is a bit of a pig when overclocking, i did manage to boot at 3.95GHz, but now run stable at 3.5GHz. the board voltage options were revised in a later revision which seemed to improve things hmpf :/
when i add more ram, the overclock becomes unstable, even with more ram volts. which is why i'm only using 2GB ram. i'd like to go to vista 64 and whack some more ram in there but i'm not happy to sacrifice the overclock for vista hehe.
looks like i'm trying to talk myself into buying a new mobo, but i've no idea what chipset or brand at the moment. must be a good clocker. ddr3??
pretty sure i dont need to change my processor.
can't really justify gfx card upgrade.
current spec
Ati 3870x2
problems:
