Hi,
I'm building a computer around the Gigabyte GA-H67N-USB3-B3 motherboard.
As this does not have on board wireless, and the PCI slot will be used for a graphics card, I assume the only way to add wireless is through a USB wireless adapter.
Simply then:-
1) Are the any usb wireless adapters that a better/worse? Any recommendations?
2) Are there any significant differences betwene usb adapater wifi and say pci or onboard motherboard wifi? Should I look for a board which has built in wireless?
Thanks for you helps
Simply then:-
