Best UV Dye?
16 Sep 2006
UV Dye got drawbacks??
I've ordered Tygon 1/2" tube for my first water-cooled system and plan to use a mix of distilled water and HydrX for the coolant.
Does UV dye have any -ve effects on coolant quality/flow rate etc?? :confused:
Well usually dyes have particles in the water which can clog stuff, but the HydrX solution is very good and doesn't cloud when mixed correctly and won't hinder performance.
