Best UV lighting?
10 Dec 2014
Hey everyone, just wondered if anybody can recommend any decent UV lighting? I recently bought and fitted my first cooling loop and am looking for the best overall effect for the UV reactive blue Mayhems X1 fluid I filled it with.
I heard the X1 UV blue isn't really very reactive so should I get some UV dye to add to the mixture?
I was going to go with a cathode kit but are LEDs better? Space is a bit tight as I'm using a Corsair Carbide 300R which is already pretty much jam packed with cables and now have an XSPC bay res taking up what little space I had left so not sure where I'd put an inverter, am also going to add my GPU to the loop soon.
Any suggestions and links would be welcome, although I noticed pretty much all UV lighting is out of stock on the OCUK store.
Quick vid of my build seconds after I powered on the pump for the first time for a leak test
