Best Value Card for i7 build
24 Oct 2006
Sheffield
Im torn on what card to get for this build. I dont want to spend more than £150 quid. Which gives me the option of the gigabyte gtx 260. Also there is a super overclocked version, would there be any advantage of this? Or any other cards?
Is there any dx 11 compatible cards under £150. Would like dx 11 as all other hardware will be high end.
Depends on what you want with the 'value'. I'd recommend a 5770 as they're pretty powerful xfired and cheap. That's down the line but right now it'd give you access to DX11 and it's a pretty easy to run, quiet, cool card. Not sure if anything beats it in power in that price range though.
