Best value Custom cables?
19 Aug 2005
Beds, UK
Hi All, I need some custom pcie cables, or just shorter ones without the second connector. Psu is older SF750, so corsair type 4 I think.
Where are people going for these in the UK?
Thanks
I have the same Type4 PSU powering my sig .... What are you powering ?
I would honestly go with Corsair's premium line
With all the issues with connectors melting I decided to pay the extra for peace of mind
I have a 9070xt and i need two 8 pin pcie. Possibly 24pin cable, the one I'm using is ok, but a bit long. It's a SFF case, fractal terra, so excess cable is problematic as it has nowhere to go.
so im not sure if OcUK still sell them but i know CableMod will make cables to the size you need there just not what i would call cheap.
there is also Modpcuk that will make type 4 cable to you measurements
i'm going to build them myself. i'd like a 24 pin cable that fits better. the best way to achieve this is to DIY it. its a short run with a bend (in on itself) which means that for best results, all cables need to be slightly different lengths. Plus its MUCH cheaper to DIY.
Thats guys.
