Best value upgrade for current machine?
22 Jul 2014
Oxon
Hi,
Debating when/what to upgrade my current machine to:
Intel Core i5 4670K, 8GB DDR3, GTX 970 on a 27" 1080p VA BenQ monitor.
Would it be worth upgrading the monitor and graphics card with the following?
My basket at Overclockers UK:
Total: £468.94 (includes shipping: £0.00)
I only manage to game for a few hours a week but I'd like a bigger monitor with higher resolution. Seems daft to spend almost as much getting a smaller 27" monitor with G-sync to use with my 970. I don't play competitively, mostly strategy games, some L4D, CS:GO occasionally.
I'll then upgrade the CPU, motherboard, ram and storage at a later date.
Another option is a 4K monitor with Freesync and the Vega 56?
Total: £239.99 (includes shipping: £0.00)
Thanks both -
And just to check, my current CPU won't hold back the Vega 56 too much? It's overclocked to 4.4GHz
Nothing that you would notice as a casual gamer - plus you have nothing to compare it with.
If you're hanging onto the setup for a while longer i would sell the 8Gb and insert some second hand 2 x 8Gb sticks.
(Preferable to have 2 x 8gb if clocking as less strain on IMC)
Thanks both -
You better wait for release of Zen2 before considering upgrading CPU.
9900K level processing power likely drops to sub £250 price level, with hundred more getting 12 cores/24 threads.
Release should be in Computex month from now.
