Best VGA cooler for an XFX 4870
6 Feb 2008
Looking at changing the cooler on my 4870.
What is the best one?
What else do i need?
Is it easy to change to new heatsink?
I presume i will lose my Warranty once i remove the heat sink?
Arctic Cooling Accelero
Nothing - its all included
Yeah its pretty easy, you might need a small screwdriver to pry out the power connection from fan to card, mine was on really tight
Yes warranty gone, unless you swap them back and blag it :D
I am also thinking of replacing my stock HD4870s cooler, but I have two of tehm one with a better cooler anyway so would it be worth me sticking this cooler on both?
well I have no idea tbh means onces got sapphires toxic cooler (not a toxic card) and I can't buy one without the other :S
sorry to nick the thread :p
stick the 2 acceleros on, theyre great, I had problem b4 with the vortexxs in my VDDC's kept overheating, I coulda just bought RAM sinks for them but decided to go for the new coolers instead, theyre a bit noisier (accelero louder than vortexx) but cool better, and I got 2 in xfire with both so no probs fitting etc
