I'm pretty much settled on building a custom water cooling setup (based on sound advice from several of you in these forums
So I've been checking out various components, but would like to know what anyone recommends for:
- Pump (minimum flow I should look for? What's best brand, source?)
- Radiator (best for an internal fit inside an Eclipse 62 case?)
- CPU block
- GPU block
- Tubing (best width, brands?)
Any other recommendations, like:
Best coolant?
Anti-algae fluid worthwhile?
Any other bits and bobs I should make sure i have before starting out?
I really appreciate any advice, especially from those with direct experience of the components themselves - good or bad!
Cheers
- CPU block
- GPU block
Best coolant?
Cheers
