- 26 Aug 2004
- South Wales
I was looking at the Swiftech apex ultra kit and the XSPC dual extreme.
Then i noticed the swiftech h20 compact with dual rads, which one of those is best? or is it still better to buy custom parts?
also i'd rather buy a pre watercooled case than having to fit everything myself, im looking for quiet & much better than heat sink air cooling.
Dont want an expensive case to put everything in, as long as it looks ok.
advice please
advice please
So if you bought the contents of the Swiftech kit seperatly form varuious stores it would give greater satifaction?
