Been really considering changing to a mATX or Mini ITX set up. Been thinking of keeping current CPU, Ram, GPU and HDD's. Just need case, MB and possibly PSU?
sell your mobo, case and psu for some money back and get these.
the case only has room for one hdd and two ssd's, i have a 1tb storage and 64gb for boot/main programs, might be better if you either kept 1 500gb, changed for 1tb and tried to fit an ssd in the budget too. it all depends on how much you get back from the components you sell.
Yup,it's about the smallest,decent mitx case that will take the longer gfx cards.
If you arent too fussed about size,the Cubitek Mini Tank is also extremely good although it is rather large for an mitx case.
You can however pack a seriously large amount of hardware into it including a vast amount of hdd's,beefy psu's,long gfx cards and ample room for H50's/custom watercooling.
If/when Z68 mitx boards appear my current SB mitx setup will be going into one of these monsters.
