ok heres my problem, handed to me by a relative.
he has a hyundai f2 evolution coupe; apparently this car is quite rare in this country and it has gone wrong.
he can probably fix most things himself, just farming out the electrical work to an automotive guy but this guy will need the wiring diagrams etc.
on this page http://www.newtonnet.co.uk/coupe/ there is a manual but it is all in separate pages.
originally when he gave me this problem i installed a trial version of offline explorer for him onto his laptop and used that to download the entire 'project'.
in his noobishness he let the trial expire and (he says) it wiped out his project (the manual)
so now he wants it in a more useable format that he can give to people on a cd so they can print out the relavant pages etc to suggest work that needs to be done etc.
Im very hazy on this but i seem to remember you can turn multiple documents,images whatever into a single pdf file.
can anyone advise me as the best way to go about this as, as much as i want to help the guy i really dont fancy manually adding 500+ pages of jpgs to some kind of program (although i might have to
Im guessing i will need to buy adobe acrobat pdf maker thingy ??
or is there a more elegant solution ??
)Im guessing i will need to buy adobe acrobat pdf maker thingy ??
